Old 05-02-2024, 03:02 PM
Default Cub cadet 1812 electrical issues
I'm trying to get a cub cadet 1812 running that's been sitting about 20 years.
When I bought it home the ignition switch was missing.
jumped the solenoid and it cranks.
Replaced the ignition switch and hooked up the battery and it will not crank with the key
noticed two of the safety switches were bypassed and the connections were corroded. replaced the terminals and taped them up.
have constant power to the black wire on the ignition switch plug. when turning the key to the start position I get 12v at the yellow wire on the plug. can't get any power to the starter solenoid to activate the starter solenoid.
Old 05-03-2024, 07:44 AM
CubDieselFan's Avatar
Do you have an electrical schematic? There are several safety switches that have to be made.
What is your serial number? There are 2 schematics for the 1812.
