Old 05-08-2024, 01:38 PM
CubbaCudet CubbaCudet is offline
Default Changing blades on tractor
Hello,
For the life of me I cant figure out how to loosen the bolts holding the old blades on my SLTX 1050.
Are the threads backwards? I used a block of wood to keep the blade from spinning (per instruction) and used WD-40 to loosen it but no luck.
Do I need an impact wrench? I removed the deck and flipped it upside down so the bolts are easy to access.
Also, any idea what size bolt holds the blades in place? 15/16? Instructions say nothing. YouTubers say several different sizes and I dont have money to buy a bunch of different sizes.
Thank you!
You only need two things in life: duct tape and WD-40.
If it's loose and supposed to be stuck, use duct tape.
If it's stuck and needs to be loose, use WD-40.
Old 05-08-2024, 02:08 PM
Red Dave Red Dave is offline
If I were you, I'd be using an impact gun.
But then, I've been using an impact gun on mower blades for many years. Between running, grass juice and corrosion those nuts can get very tight.
Just don't over tighten with the impact when you put them back on. Just make them tight and stop.
One other thing I've been doing since back in the 1960's, is to put a dab of Neversieze on the threads before putting blades back on. Just a dab, don't overdo it or that stuff gets everywhere.
Old 05-08-2024, 04:00 PM
Measure across the flats of the nut to determine size;
Old 05-15-2024, 05:24 AM
+1 on what Red Dave & Fins said. Harbor Freight has some pretty cheap impact and regular sockets that I use without any issues. I have an electric impact wrench I use on decks that works pretty good. Be careful using a breaker bar or something like that. I bent one of my newer decks that way because they are pretty thin now and using a cheater bar will bend them. WD40 isn't penetrating oil. Get some Kroil, PB Blaster or other good penetrating oil.
Old 05-15-2024, 08:15 AM
Or a gas wrench
Old 05-15-2024, 07:48 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Large shifting spanner and a piece of pipe to go over handle , tap tap tap with a rubber mallet and the nut should be on the ground
Also have the deck tilted blade side down a couple of degrees so you do not drive the spindle shaft out of the bearings
Oz
Old 05-15-2024, 09:50 PM
3/4" drive Ingersoll with #150 air line should "ger er done" quicker than you can lick ice cream off your shirt on a *100 summer day
Old 05-16-2024, 08:58 AM
"Large shifting spanner"
I give up, is this new tech name for a Crescent wrench or what??
Old 05-16-2024, 09:49 AM
ironman's Avatar
ironman ironman is offline
to Brits, shifting spanner = adjustable wrench.
Old 05-16-2024, 01:33 PM
To me, that would be a last resort!
Good way to bust some knuckles and round off the corners of the nut!
Tags
blades, replace blades, sltx 1050
