I just got a used 3 point hitch off of E-bay for 137.00 for my 149. What I was wondering was if you could use the same bolts that were used for the rear dif. cover on the bottom hitch? Can you use those same bolts, or do you need to get longer bolts so they don't pull out under a heavy load? I'm anxious to get it on, but not so anxious that I would want to mess it up.
Thanks guys! |
You need 1/4" longer bolts. I suspect what you already have is 1" long bolts, so you'll need 1 1/4" long bolts.
