Old 05-18-2024, 04:53 PM
jonasl682 jonasl682 is offline
Default Cub Cadet 682 with magnum 18 wiring help
Does anyone know where to find the diagram Roland had made for the updated wiring changes needed for a 682 with magnum 18, i picked up a cheap 682 with the wiring harness wrapped around the drive shaft (not sure how that got accomplished!) it came with a used harness but it doesn't match to the kohler magnum 18. my cubs serial # 792334 Thanks all!
Old 05-18-2024, 06:09 PM
The old harness is prolly from the original KT 17 engine, check the wiring diagrams in the tech section.
Up to 534 and counting...
Old 06-03-2024, 01:50 PM
Thank you!
Tags
682, magnum 18
