Have a new carb to replace the old gummed up one... it looks like it unbolts from the BOTTOM.... am I seeing this correct? If so, can anybody direct me to the removal/reinstall procedure.
Remove the air cleaner, base, hose, linkages, fuel solenoid wiring, and you have to remove the 2 nuts at the bottom of the carburetor.
Remember what holes you remove the linkages from.
Does this help?
Take pictures.
Vanguard carbs are easy to clean. Have tried cleaning the one on the machine? Just remove the four screws on the top and you can clean most of it. You might need to remove the shutoff solenoid also. Is your new carb a new el cheapo from Scamazon?
