Old 06-02-2024, 03:35 PM
Nwt1010 Nwt1010 is offline
Default ZT1 Ultima
I have a 2020 ZT1 42inch deck, My blade pto clutch wouldn't engage, so I noticed it wasn't getting any power, initial inspection I thought the wiring was broke due to wear / vibration against the metal frame where it goes from topside thru the frame to the bottom. I rewired it, not realizing when I engage the pto, the actually clutch is freely spinning, pulling on the wiring. I had done a mow, came back and realized it would not engage, this time the wiring was shreaded. I believe I had a clutch stop break / fall off (that braces the clutch), but I am not seeing any diagrams when I search for this.. When I pull up the model number for parts, I do see a clutch stop bracket but I haven't found any photos or diagrams for this. Would appreciate any help!
Old 06-02-2024, 05:22 PM
Here's what I found from the "look up box" above. Does this look like what you're missing?
I'm not sure of your model number but this is where the above diagram came from.
ZT1-42 KH (17AREACS010) (2020) (ULTIMA ZT1)Assemblies for ZT1-42 KH (17AREACS010) (2020) (ULTIMA ZT1)Clutch Keeper
Old 06-06-2024, 08:35 PM
Default Reply
Thanks for your help and getting back to me. I believe that is the correct parts. I had pulled up my serial number and the only part that had come up when I searched was Item # 2 in the diagram. I will go back and see if I can find the other part and the fittings. Upon looking under the deck of the mower, I still do not really see where this exactly goes. I see a small sheared piece of metal that is threaded to the backside of the right hydro pump. So hopefully I can run across a diagram or photo that shows it in place.
Thanks for your time!
Old 06-18-2024, 09:06 PM
ramjet777 ramjet777 is offline
Default keeps dieing
hey need help got a zt1 50 zero turn , its runs for amin or so then back fires and dies. I drained tank and cleaned it, blew out fuel pump, cleaned plugs, started it up run around min or so backed fired and died
