Old 06-03-2024, 07:16 AM
Mlong21 Mlong21 is offline
Default Zt1 54 starving for fuel
Hello, I'm new to the site and have ultima zt1 54 zero turn that of course just ran out of warranty 4 months ago. I believe I'm have an issue with the fuel. It acts like it is starving for fuel at times and if I put on the choke while it is running for a few seconds and take it back off, it fixes it for a while. Sometimes 5 mins and sometimes 30 mins. I have drained fuel tank and replace fuel filter and fuel pump. Also took off carb and cleaned it as well. Still no luck fixing it. Just weird that if I choke it for a few seconds it will fix it for a little. What are your thoughts? Thanks.
Old 06-03-2024, 10:28 PM
Farmall450's Avatar
Does taking the gas cap off change anything?
Old 06-04-2024, 04:34 AM
No it does not. I even tried snipping off the point on the fuel shut off solenoid and that did not help either. Have a new carb ordered and will be here today to try. Can't believe it would be bad with less than 100 hours on it but who knows, worth a try. Worse case I have an extra one laying around for one day. If that doesn't fix it, I'm lost.....
Old 06-08-2024, 07:23 AM
Next I changed the carb and that made no difference so the next step was the ignition coils. I replaced the coils and all is food now!
