I'm thinking on adding a Hydraulic pump to my 108 later this year, I debating on making a setup like this, pictures attached to pull a scraper. I see this JD have a PTO pump that he made a bracket for. I was thinking on doing the same or use a Power Steering pump. I don't ever plan on getting a 3 point since. What do yall think?
Yes, that is how a lot of owners add a pump. Here is how I added a pump for my FEL.
DSCN3402.jpg Here is the pump I used. https://northernhydraulics.net/produ...ncentric-10566 I have seen some guys use an old power steering pump also but the mounting is different.
I'm sorry, I do not. It was something I made up on my own however I did purchase the pump mount from another member that is not active anymore.
https://www.onlycubcadets.net/forum/...ead.php?t=4887
I used a GM power steering pump and a JD valve to add hydraulics to my 100.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
It’s a homemade mount. I had to add a jack shaft and an additional belt to drive the pump the correct direction.
