Old 06-05-2024, 09:09 AM
1811woody's Avatar
Default Repairing plastic side panel pins tricks/tips?
What are you guys/ gals doing to repair the plastic pins for the side panels? I've got a plan thanks for the input guys.
Old 06-05-2024, 11:45 AM
I assume that you're talking about Cyclops side panels. I cut them off flush then I use some 3M structural adhesive and some screw in studs
Old 06-05-2024, 12:43 PM
1811woody's Avatar
Yes Sam for the cyclops I was thinking it is the only one with the plastic pins but I've been wrong more then once in my life.lol As far as the studs it looks like a great way to go about it. Are you able to get to the bottom stud easily?
Old 06-05-2024, 03:04 PM
I don't put a nut on the bottom one, the clip that fits over the frame holds it in place but you can remove the black plastic grill to get at it if you want to put a nut on it.
Old 06-05-2024, 06:25 PM
1811woody's Avatar
Ok got it thanks Sam do you have any tricks for repairing the plastic head light stand offs for cyclops?
Old 06-11-2024, 07:12 PM
Rex B Rex B is offline
I cut the posts off flush.
Then I make a short tapered replacement post (lathe work) with a 1/8" hole down the center. I insert in that hole a 1/8x1.5" cotter pin and spread the legs slightly. I attach these with JB Weld Plastic epoxy, which works amazingly well for these panels. The epoxy is tougher than the plastic. Never had a joint fail.
The repaired panels snap into place much like the originals, then I drop a cotter pin in them for a safety. Alternately, you can attach a spring across to tie them together. The old universal throttle return springs are just right for this purpose.
Not the best photo. I'll see if I have any better.
Old 06-12-2024, 09:18 AM
1811woody's Avatar
Thats another good option and you do nice work !
Old 06-17-2024, 07:39 AM
Default Better photos
Here are some detail photos of my method, This was two years ago and still holding up fine.
Old 06-17-2024, 07:51 AM
Default Plastic epoxy
This is the epoxy I used. Very good stuff, also works on just about anything you would need epoxy for. I have repaired cracked panels with metal reinforcement with excellent results. The cowl is a difficult repair. These photos are an incomplete project. The cracks are epoxied, then sanded flat and reinforced with aluminum using the same epoxy.
Amazon, WalMart, auto parts or hardware store.
J-B Weld 50133 Plastic Bonder Structural Adhesive Syringe - Tan - 25 ml
https://www.jbweld.com/product/plastic-bonder-syringe
Old 06-17-2024, 02:45 PM
1811woody's Avatar
Nice work it looks like its good and solid.Thanks for the tips
