Old 07-02-2024, 09:14 PM
Zero1's Avatar
Zero1 Zero1 is offline
Default Kohler 20 v-twin starters
Has anyone had luck with these starters?? I need another one! first two were junk! 50 bucks apiece they should last more than a couple weeks! Thanks
Old 07-02-2024, 09:26 PM
CubDieselFan's Avatar
Just use the Kohler starters. I have tractors so I have spares. Where are you buying yours? Chinese starters?
Should be under warranty of they are 2 weeks old?
Old 07-03-2024, 12:04 PM
Zero1's Avatar
Im reading oem kohler twin 20 starter has 9 teeth cheap china starters have 10 teeth! Is that why they don’t last long?? $228 oem! Wow and you have spares!!
Old 07-03-2024, 12:13 PM
I have a lot of tractors and can move parts around if I need to. I have used spares.
Old 07-03-2024, 12:17 PM
That is pretty high for OEM. I see them new, online for 160.00 with free shipping.
Old 07-03-2024, 01:12 PM
Zero1's Avatar
I guess you get what you pay for! Do you know if the number of teeth makes a difference? High torque starter hits hard, things brake! $160 is better but I didn’t pay that for the whole tractor !0!
Old 07-05-2024, 06:45 AM
evhevh evhevh is offline
Talking
You are just a bench grinder away from changing your 10 tooth to a 9 tooth...
Old 07-05-2024, 04:40 PM
Zero1's Avatar
WHAT? You can do that??? And it lowers the torque???
Old 07-06-2024, 07:23 AM
No, don't do that...
Old 07-07-2024, 08:26 PM
Zero1's Avatar
HAHA!0! Didn’t really think u could do that! Almost made sense though!! Would have been cheaper than the generation 3 starter with 9 teeth and a welded nut.also a thicker shaft.
