Old 08-02-2024, 08:22 AM
IHCubCadet147's Avatar
Default Some work on the 1450
Last week I washed my 1450, and brought it in the garage to wax it and do a couple small things on it. I noticed the nut on the drive lever rockshaft was loose, and when I tightened it the drive lever wouldn’t move. The shaft was stuck in the bushing. It must have been like that as long as I had it and I never noticed. I got that freed up and now the drive lever operates much better, but was way out of adjustment. I tried adjusting it, and couldn’t get it right. I did some reading on here and everything pointed to a worn trunnion. I pulled the fender pan off and sure enough it was worn. The damper plate was also stuck on the shaft. That would explain why the hydro was always jerky on this one. I know this is common on these, but I haven’t fixed one yet. I got the slot welded up and ground back to square, and put in new springs and pins. The cork gasket was leaking too, so it got a new one, along with new fluid and a filter. I got it all back together and it is much nicer now. I should have done this a while ago. My 129 needs the same things done, that may be my next project.
Old 08-02-2024, 08:44 AM
Now with that done, I could finish what I originally set out to do. I put on my new gas cap and IH emblem that I got a few years ago, but never put on. Changed the burnt out headlight. Buffed and waxed the whole thing. It looks pretty good now, just needs a set of taillights. Now it’s almost too nice to put it to work.
Old 08-02-2024, 09:54 AM
WOW!!! That slot was really out of whack!!
Nice job!
Old 08-03-2024, 01:43 PM
Nice job!
You have taillights, you need the lenses, and a set of decals like these. PM me
Old 08-04-2024, 08:10 AM
Nice job IH! Is that a copper plate you used under the trunnion? I've done that several times on different things and it works great.
Old 08-04-2024, 12:48 PM
Nice job!
Thanks!
I need the base too. This tractor must have sat outside for a long time without lenses. Everything is rusted and pieces of the socket are broken and missing.
Yes it is. I saw that mentioned in a few old posts on here, and it did work good.
Old 08-11-2024, 08:45 AM
jbrewer's Avatar
jbrewer jbrewer is offline
You did a great job with that trunion... that thing was about all used up.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-12-2024, 08:39 AM
Thanks John.
Old 08-22-2024, 08:34 AM
I got a taillight (I already had one off a parts tractor), and a set of NOS hood decals. Thanks again Lew!
I got the taillights on and wired up. The decals will be going on soon. Now it’s kind of bothering me how crooked that IH decal is, but I think I’ll leave it for now. This tractor has all original paint, so it must have came from the factory that way.
Old 08-22-2024, 01:07 PM
jbrewer's Avatar
Oh, that's really looking good now!
Lights are working really well too.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
