Old 08-02-2024, 03:44 PM
2wheelgnnr 2wheelgnnr is offline
Default grass building up under deck? any help
Just got my brand new shiny ZT1 50. Now IF THEN SENT THE KEY WITH IT ID BE HAPPY......but they are bringing on this afternoon...but we will see.... people so incompetant these days.... anyrate not to digress but.
with that I was thinking if applying something like wd-40 or even PAM to the underside of the deck to help combat grass build up under the deck. I have the fabricated deck. I know nothig is 100% and over tile it will but....just so I can keep it from not getting too bad. when changing out blades or sharpening I always scrape off the underside anyways but just wondering if anyone has had any luck with the use of somethng to help it......I know a big help is I wont Mow WET grass for sure!!!!!
TIA....
Old 08-03-2024, 07:30 AM
Don't mow when the grass is wet.
Blow everything off when done.
Old 08-04-2024, 08:53 AM
Mow the sticks, they help to clean the deck, so does mowing on sandy ground.
Other than that, just use your putty knife to clean out under the deck, as clippings are very corrosive.
Old 08-11-2024, 09:46 PM
Smooth, new paint doesn't allow as much to stick to it, but depending on what you are mowing, rocks (etc.) chip away at it quickly and gets you back to where you probably already are.
Old 08-13-2024, 06:21 AM
You can use this stuff but it didn't last too long for me.
https://www.tractorsupply.com/tsc/pr...-coating-1-gal
