Old 08-17-2024, 02:10 PM
Nathandove65 Nathandove65 is offline
Default K301 Carb no start issue
I have a cub 1200 with a 12hp kohler that will not start I pulled and cleaned the carb, checked compression and spark. I have power at least to the plug and fuel getting into the cylinder. I do not k kw how to adjust the carb to get it started, is it a fuel or plug issue? All help appreciated
Old 08-17-2024, 06:30 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Tell us how the problem got started.... Was this running recently? Is fuel fresh? Timing on the mark?
Plow blade
#2 Cart
QA36 snowthower
Old 08-17-2024, 09:54 PM
Well sounds like you are tracking it down. You may have already
done this but if not. You can find the engine you are working on in the
technical library of the site here. That will at least give you the basic
settings for the carb.
When you say it "Will not start" what are you saying? Does it turn over
and not fire? Does it not turn over? The more info you can provide
the easier it is for folks to help you.
Ken
Old 08-17-2024, 10:03 PM
athomas's Avatar
athomas athomas is offline
1 1/2-2 turns out from seated position on the low speed ( idle) screw and 2 1/2 turns out from seated on the high speed should let it start as far as the carb is concerned ! will it fire if carb cleaner is sprayed directly into the carb while cranking ?
