Old 09-03-2024, 12:18 PM
Ewilliams's Avatar
Ewilliams Ewilliams is offline
Default One bottom plow on a 982
Hello. I have a brinly one bottom plow. Wanted to know if I could use it on a 982 with a 3-point hitch. Or would I be able to use it on an original? I would assume the seven horse motor might not be able to do it any suggestions would be greatly appreciated.
Original, 1512, ih 982, ih 682
Old 09-03-2024, 02:39 PM
An original should handle a 10" just fine in the right conditions.A garden plot that HAS BEEN a garden plot amd NOT SOD!!
The 982 is a no brainer, if it won't handle a 10 Brinly, it ain't much of a Super!!
I pull a 12" Cat 0 with my 882 all the time and a 10" sleeve hitch unit with my 128, no issues.
Which hitch do you have on your 982?
Good luck and have fun!!
Old 09-03-2024, 05:31 PM
Farmall450's Avatar
^ this, we need to know your hitch type, since a true Cat 0 3 point won't work w/ a sleeve hitch plow w/out adapters.
Old 09-03-2024, 08:23 PM
Ewilliams's Avatar
I have the cat 0 hitch on the 982. Will it work on the 982?
Old 09-04-2024, 05:20 AM
If your plow is the sleeve hitch type then you will need the adapter like this one to use with your cat 0 hitch.
https://www.ebay.com/itm/23487410117...AaAnhNEALw_wcB
Old 09-04-2024, 05:54 AM
What kind if a drawbar does your cat 0 have on it now.
One like this, regular Brinly type?
If so, I have an adaptor for that to pull sleeve hitch attachments.
No need for yet another drawbar for a specific use only.
One can bolt on nearly any adaptor to this type for any chore you may need.
I use mine for sleeve hitch, installing a ball hitch to moving trailers, or just plain towing a cart, roller, dethatcher, rear blade, drag, lawn sweeper you name it.
Here's the one I build.
If you have a Cat 0 plow or other such attachments you will need the the Cat 0 style drawbar (2nd picture) I also have available as well.
Old 09-10-2024, 01:54 PM
Ewilliams's Avatar
I ordered the cat 0 hitch adapter on eBay. And now installing it. It doesn't come with any instructions but it looks pretty straightforward. I've collected Cub cadets for many years but never used a cat 0 3 point hitch. I'm assuming the bolts are for tightening the plow once it's on. If anyone has a picture what it's supposed to look like when the plot was on I would really appreciate it. Thanks for all your help
Old 09-10-2024, 01:57 PM
Ewilliams's Avatar
Another pic
Old 09-10-2024, 02:24 PM
Ewilliams's Avatar
I think I have the plow on the correct way except for it's swaying side to side then I assume that's what them bolts are for. Not sure how to use them to keep it from swaying.
Old 09-12-2024, 10:28 PM
Farmall450's Avatar
There's normally a draft plate w/ 2 big bolts to stop the sway, but you're not really supposed to use it for plowing (back the bolts way off at least). It'll do its own thing once you get it in the furrow.
