Just aquired a nice 1811 and was wondering if a wide frame sleeve hitch will mount on to this thing ??? pics would be nice ...thanks Rob
It will not. A 1811 has a aluminum rear end and it is not recommended attaching a sleeve hitch to it. Plus the bolt holes are differnet.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
The top part will work with a correct lift rod. The bottom part will not bolt up though.
Extreme Motor Works makes what you need. There lower part addresses(fixes) the problems the aluminum rear has. Check it out and see. JOE
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
I have the 1811 and had the hitch modified to work with a tiller but it tore up the bottom bolt holes so eventually I sold the tiller and went to a walk behind tiller.
Since that time i struggled with the leaks just with the bolt on hitch, finally stopped the leaks and installed this hitch plate that bolts directly to the rear frame. 703-1943A-0498 - RF Houtz has this plate for $47.. also sometimes on ebay too you can find them. Now this probably wont work for your needs for a rear lift without modifications but wanted to at least mention some other options. |
That's a sharpe looking 1811! Got any more picture's?
Sorry to hijack the thread. |
Methos,
Here are several before the lugs and after. Found the 4 lug tires on CL locally for $260 including the front wheels/tires with new bearings! |
That's one sharp 1811!
Does anybody have a wiring diagram for an 1811?
