Old 10-09-2024, 02:47 PM
PolCadet PolCadet is offline
Default GT 2100 -> Damaged fuse
Hello.
How to clean the contact that receives a fuse from the fuse box? What liquid product can be used or what other method ?
Tanks for infos.
Hello.
In the fuse box, someone can describe me or refer me to a WEB link to find out the reference of each fuse. I am making this request because a 30 fuse has been damaged, seems to have heated up. What can be the cause of damage ?
Thanks for reply !
Old 10-09-2024, 02:58 PM
Dirty and/or corroded terminals or wiring in general.
Cruddy wires & such causes high resistance and related heat.
Plastic does not like heat.
Old 10-10-2024, 08:29 AM
Agree totally, corrosion is not your friend.
If you are asking, those fuses are auto parts store items.
Old 10-10-2024, 04:38 PM
ironman's Avatar
ironman ironman is offline
I need Lucy to splain to me...
high current causes heat....heat melts plastic
corrosion causes high resistance.....
high resistance reduces current....
how do corrosion make fuse melt???
Old 10-10-2024, 06:01 PM
Corrosion allows arcing, and that makes heat.
Just like a loose Bat- tree terminal.
Old 10-11-2024, 10:31 AM
Billy-O's Avatar
Billy-O Billy-O is online now
I would think that added resistance causes more heat.
Plow blade
#2 Cart
QA36 snowthower
