Old 11-28-2024, 07:32 AM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
Default Air compressor
I ordered and installed a new switch on my father’s air compressor
It works , shutting off at 125psi. But it leaks off pressure until down to 80psi
The instructions said nothing about the adjustment of the pressure springs.
Can anyone here help provide some insight
Thank you
Old 11-28-2024, 08:29 AM
This should help. I believe this is for a water pump but should be just like your switch.
https://www.youtube.com/watch?v=1VNSv7xVzzU
Old 11-29-2024, 11:40 AM
ironman's Avatar
ironman ironman is offline
Thank you
It would help if you provided more information, like what was happening before you replaced the switch.
It sounds like you have a a faulty or dirty check valve or unloader valve (maybe both). That stuff is explained here....
https://tameson.com/pages/compressor-unloader-valves
https://tameson.com/pages/check-valves
Old 11-29-2024, 10:49 PM
garydee's Avatar
garydee garydee is offline
Do you have a valve on your compressor to isolate it from any airlines or hoses that are connected. Perhaps the pressure in the tank lowers down due to leaks in the connections beyond the tank.
If you didn't have leak down before replacing the pressure switch and your instructions don't explain how to adjust the settings, you may be able to find more extensive instructions online for adjusting the switch to the desired on/off pressure settings.
Next step would be to suspect the check valve.
Old 11-30-2024, 07:18 AM
The unloaded portion of the pressure switch was leaking
After replacing the switch it shuts off at 125 then bleeds down to 80psi
I was mistakenly assuming the problem was with my switch, once I changed focus to the check valve I now understand that the check valve is leaking allowing the pressure switch to bleed off pressure out of the tank instead of just relieving pressure in the pump.
A new check valve is on order
