Old 12-04-2024, 03:42 PM
jon81SC jon81SC is offline
Default How to move a 1210?
Have a Cub Cadet 1210 that hasn't run in 5 years which I have to move out of my shed before it can be picked up. Couldn't get it to start then ("varnished," fuel lines?) so no way I can get it to start now. Haven't been able to move it in neutral. Is there an golf cart type of "tow" switch on the 1210? Thank you in advance!
Old 12-04-2024, 06:07 PM
No there is not. You can push it or tow it but you can only go baby steps.
Old 12-05-2024, 12:01 PM
Hi darkminion,
Thank you for your prompt reply! Bummer that there is no way to roll it, but just a 1st world problem!
Old 12-05-2024, 06:05 PM
garydee's Avatar
garydee garydee is offline
With a helper, you might be able to move it by putting a small hand truck under the transmission between the rear wheels. Block it up if needed...and push hard!
Old 12-05-2024, 07:15 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
In order to move my 782 around I put one of these under each rear wheel.
https://www.harborfreight.com/18-in-...lly-58312.html
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 12-06-2024, 06:55 AM
The 1210 has auto relief valves on the hydro so you can push it or pull it at a slow walking pace for short distances.
Old 12-07-2024, 09:48 AM
dale c. dale c. is offline
make sure the brake isn't set . if you lift 1 rear tire off the ground the roll pretty free.
Old 12-07-2024, 10:31 AM
garydee's Avatar
Say, are you moving that tractor out of a shed or over rough terrain or, perhaps over a concrete floor? Bigger wheels will make it easier to roll especially if over rough ground if you are worried about the relief valves. Sam says you are ok to push it, so I would just give it the heave-ho and get it moved.
Old 12-07-2024, 06:21 PM
Billy-O's Avatar
Billy-O Billy-O is online now
5 years?? If the tires are low or flattened, inflated them to proper pressure. It will move easier.
Plow blade
#2 Cart
QA36 snowthower
Old 12-07-2024, 06:31 PM
garydee's Avatar
Back your car up to that shed and hook one end of a chain around the front axle of the 1210 and the other to the frame on your car and drag that sucker to where you want in to be! Simple! Git-r-done!! Don't waste any more time thinking about it!!!
