Going through electric PTO in my 1450 due to it seems like it is constantly engaged. When the engine is shut off the pulley will spin but it really drags and its obvious the air gap is not correct. After taking it apart I see this with all the rust (tractor has set for 4-5 years) and the bearing is in the pulley is also bad. My question is can I wire wheel these surfaces to get rid of the rust and clean them up without hurting the mating surfaces? Also, is there anywhere to get the shims for the original clutches?
Thanks, Tom
IH Cub 1450 IH Cub 126 *Under Construction* |
You can clean them up. I would replace the bearing while you are at it. As for the shims, Mc Master Carr may have what you need.
Up to 534 and counting... I give up updating my profile! |
Ok, I figured I could but I wanted to check first. I've got the bearing out and ordered already, I thought about McMaster-Carr but didn't know if the shims were specific or not. Thanks!
When the engine was running I took a broken wooden shovel handle and tried to see if it would stop the pulley and it wouldn't, it was turning like the switch was on but it wasn't and I verified there was no power to it at the time. Doing what I did should have stopped the pulley right?
The bearing was in bad shape and with all the rust build up I feel like that was the issue. You could turn it by hand when it wasn't running but it was pretty tight and sounded bad.
I cleaned and replaced the bearings on mine before winter and wire wheeled it to get rid of the rust. If you have a good precision straight edge hold that over the 2 plates and see if they are badly worn out of true. the cleaner and flatter the 2 surfaces are the better magnetically attached to each other they will be and the less wear they will get from slippage when you engage the pto.
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller 70- 38in deck, 42 inch deck GE E-12 Electrak- front mount mower, snow plow |
If it was spinning the adjustment plate must have been backed off and those bearing must have been very bad if you couldnt get it to stop
