My local CC dealer John Labuda just called. The 3 gears ,crank,cam ,and duh???? are destroyed. Everything else ok. He priced cam and other gear. Crank gear not available. Should I search for another crank gear? Would I have same problem later? Midwest Cub I believe makes machined steel crank gear not sure if it is for a magnum. I'm new to the twins. Is this engine considered a magnum? Should I just replace with a newer engine? I need direction so as not to have another failure couple years down the road. Thanks Bob.
If you want to keep it, I would buy a new engine rather than spend the money on a repair.
Yes, you have a 20 HP Magnum.
The crank gear at Midwest Super cub is for a Command.
Here is a video from a member here. Looks like what may have happened to yours from what you are describing.
https://www.youtube.com/watch?v=m1iavMdWDV8
Thanks guys. I called Midwest before you responded they said wont fit. Engine is 'redheaded step child ' better with command. John at CC left for Drs appointment. He is ckg around how to repair. I'll speak to him Thursday. Make decision $$$$.thanks Bob.
![]() Queen Of The Quietlines! ![]() |
Looks like you are in Latrobe. I'd give Rich Patton or Ray Weaver a call and see if they have any good Magnums or Command engines available. Also a good Command out of a 2000 or 3000 series would be a good option too.
I dont know Rich or Ray. Do you have their numbers? There is a guy that has a tractor junk yard on Rt 982 near where Rt crosses Pa Pike out in the' sticks'. I'm leaning towards the command engine as I like Kohler. I thought about Briggs. I had another tractor with a Briggs the exhaust seat fell out so I'm tainted. Thanks guys.
Try our current sponsors. They have engines in stock.
I called Mr Houtz. He has a 18 hp command with about 300 hrs. I'll talk to John at CC dealer tomorrow. His wife said he was ckg. Soo we will see. Thanks guys for all the info.
