Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kawaski Engines
Old 04-19-2025, 07:57 PM
bgm1961 bgm1961 is offline
Default Oil weight recommendation
I've been living in an apartment for the past 15 years and moved into a new house a few months ago. So, I'm new to riding mowers.
I recently bought a Cub Cadet ZT1 50", with about five cuttings behind me. So far, I'm happy with my purchase, and I intend to keep it that way!
My first (5 hr) oil change is coming up. It seems that 10W-30 is the most common/prevalent viscosity sold locally.
However, the Kawaski Engine manual writes: "10W-40 is the recommended oil for most conditions." Of course, it doesn't preclude other weights, calling for them based on the operating ambient temperature range.
So, according to the manual's oil chart:
- 10W-30 is suggested for 14 deg F to 90 deg F ambient temps.
- 10W-40 is suggested for the wider range of 14 def F to 110 deg F.
Where I live in Missouri, the temp often climbs above 90 deg several times during the summer. So, their recommendation of 10W-40 seems the way to go.
BUT:
10W-30 is pretty much the only weight the local stores sell for small 4 cycle engines.
Except, Lowes does sell Kawasaki brand 10W-40! It's the ONLY 10W-40 they sell, and it's the ONLY weight sold with the Kawasaki brand. Not to mention that it's like a $1,000 per quart. <grin>
QUESTIONS:
As such, I wonder if Kawasaki recommends 10W-40 only to help with the sales of their own-branded motor oil (which again, is 10W-40), or if 10W-40 is indeed the best viscosity for 80 deg to 95 deg summer days?
So then, if it's the latter, then why don't the local stores stock more 10W-40???
What viscosity to you guys use and would recommend?
Thanks!
Old 04-20-2025, 05:52 PM
Sergeant's Avatar
Sergeant Sergeant is offline
BUT:
QUESTIONS:
Thanks!
I use the OEM Kawasaki 10W-40 Oil In My Cub Z-Force SX54. But that all My Local former Cub dealer Has In stock so I Bought a case a year ago or so But the oil is used In some other Machines engines that I have. But any brand of 10W-40 will work
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force
Old 04-21-2025, 01:34 PM
Thanks for the reply!
So, you're suggesting to go with 10W-40 instead of 10W-30? I guess my ultimate question is based on the notion that since 10W-30 seems to be what everyone around here sells, then it would seem that everyone uses 10W-30.
Hell, even the Maintenance Kit offered by Cub Cadet for Kawasaki engines comes with 10W-30!
Yet 10W-40 is the recommended viscosity (presumably due to its wider range of ambient temps). So, it seems you recommend going with the 10W-40 despite its (higher) cost and its lack of local availability?
I'm not trying to ask a loaded question although it's certainly coming across that way! I'm just trying to make sense of why Kawasaki recommends 10W-40, yet that viscosity is hardly stocked locally, and when it is, it's only the Kawasaki brand. Not to mention that Cub Cadet themselves puts 10W-30 in their Kawasaki maintenance kit.
I think I'm overthinking this way too much and should just use 10W-30. But then I'll wonder if I'm hurting my engine when the temp gets above 90 degrees. But then, given how 10W-30 is the most available, I won't be the only one!
Thanks!
Old 04-21-2025, 08:53 PM
Well if it were me, I'd just go to a truck stop, farm/home store or Tractor supply and get shell rotella 10W40.
Hell last time I was in Walmart they had it.
If its good enough for a diesel truck/tractor it will work in a lawnmower.
And if they have synthetic all the better.
Old 04-22-2025, 01:06 AM
Sergeant's Avatar
Thanks!
I'd stay with the 10W-40 But It doesn't Matter which Manufacturers 10W-40 you use
Old 06-07-2025, 01:02 PM
Greg57's Avatar
Greg57 Greg57 is offline
I'm in western NY, and plan on doing my break-in 5 hour oil change in a few days [i'm 2 or 3 hours late, oops], and I just purchased the STP premium 10w 30, 4 stroke small engine oil. For the 50 hour oil change, I may splurge and do the kohler 300 hr 10w 50 oil and filter kit. Not sure yet.
Cub Cadet XT1 LT50 FAB
Old 06-07-2025, 01:25 PM
300 HOUR OIL CHANGE?
Do as you like, but in all my years,100 hours oil change on an engine that is air cooled and working 100% ALL THE TIME is absolute maximum I'd go unless I'm trading it every year and don't care about it.
Old 06-07-2025, 02:39 PM
Greg57's Avatar
haha kohler claims 300 hours, but I wouldn't let it sit that long. 300 hours for me would probably equate to about 5 years. My kohler 7000 series manual states 100 hrs, and the cub cadet manual suggests 50 hr oil change intervals. So using the STP oil I plan to follow the 50 hour plan, and if I change to the kohler "300 hour" oil and kit, then I'll probably change the oil every 100 hours.
https://www.cubcadet.com/en_US/oil-l...oaAunEEALw_wcB
Old 06-30-2025, 12:53 AM
Ol’ Autocrosser Ol’ Autocrosser is offline
BUT:
QUESTIONS:
Thanks!
If you’re in Missouri, I’m real close climate-wise (Overland Park, KS). I have a 2023 ZT1-50 and a 2012 Cub LTX1050 KW rider with nearly 500 hours on it, both with the same Kawasaki engine you have.
I also owned and autocrossed air-cooled Corvair turbos for ten years in the ‘70s, so have lots of experience with air-cooled engines which get a LOT of cooling from their lubricating oil. I ran Castrol 20W-50 in the Corvairs, and have used that or, as a minimum, 10W-40 in both mowers. Corvairs were HARD on the oil of that period - the recommended oil change interval on those engines was 6,000 miles or 60 DAYS(!), and that oil was Black after 60 days! I had zero lubrication or wear problems with either of the two Corvairs or the Cubs I currently run. Unless you’re using your rider in cold weather that might require the 10W for the low temperature - say under 40 degrees - like plowing snow, I’d focus more on the upper end of the temperature scale.
Those Kawasaki engines are solid. Neither has ever leaked or used a drop of oil between changes. I love ‘em. You can get whatever weight oil you decide on at any decent auto parts store - you don’t need to limit yourself to the mower shops.
