Old 05-04-2025, 08:43 AM
Winger Winger is offline
Default which hydro?
Morning. can anyone confirm whether Zero turn Ultima ZT1 50" has either Hydro Gear EZT 2200 or Hydro built by Cub Cadet. Looking to buy new and EZT seems be installed in many different brands. Figure they must be dependable. Thanks
Old 05-04-2025, 07:17 PM
Sergeant's Avatar
Sergeant Sergeant is offline
All Ultima ZT1 50 from 2019 till present use the Hydro-Gear ZT-2200 (EZT). Until a year or so ago, the Hydro-Gear ZT-2200 (EZT) was the Basic entry-level Hydrostatic transmissions. Now, Hydro-Gear Makes the ZT-1800. Also, until recently, the ZT-2200 (EZT) was a sealed transmission, which you had to remove from the Zero Turn to service. Now they offer drain plugs for them. If a Manufacturer springs for the extra Drain Plugs added, who knows! I bet most are still sent out less drain plugs to most zero-turn Manufacturers. The Better Residential Hydro-Gear transmission to get for a zero turn is the ZT-2800, which is basically the same specs as the entry -level commercial ZT-3100 except the ZT-2800 has 50lbs less axle Torque and the ZT-2800 should be able to be serviced while still on the Machine.
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 05-05-2025, 07:17 AM
Default help with posting
Thanks for the info, guess i will have to look for drain plug on hydro unit. Winger
