Old 05-12-2025, 12:18 AM
Jamocha Jamocha is offline
Default Tiller belt
Recently got a 1A tiller and I need the belt that goes from the pulley to the gearbox. Anyone know where I can find one that is cheaper than from CC? I have seen some but they appear to be 13/32 x 53 3/8, not 13/32 x 53
Old 05-12-2025, 08:14 AM
The 3/8" should be able to be within with the belt adjustment tolerance.
That equates to 3/16 of an inch in the adjustment.--(3/8 divided by half)
if you think that short belt is expensive, do not look at the price of the L-O-N-G
belt!
Old 05-12-2025, 09:03 AM
Graflex45's Avatar
Graflex45 Graflex45 is offline
Does anyone have any experience with using the "proper" width belt vs just buying 1/2 inch belts? Is there any difference in belt wear really?
I have used 1/2 inch belts on both of my machines mower decks for 2 years and haven't noticed any belt wear, so when I started overhauling a no.2 tiller I just found the right length for both so I can order from my local napa. It took me 3 tries but I did find the proper length for the pto belt, for some reason its longer than it should be, a 148 1/8 belt was what I needed from the parts I put together for the mule drive and gearbox.
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller
70- 38in deck, 42 inch deck
Old 05-12-2025, 04:34 PM
I was going to try a 3/8" belt and see if that would work for now.
Old 05-12-2025, 05:46 PM
You can get decent belts on the internet that will work for that short belt as it is not making twists that kills cheap belts.
