Old 06-05-2025, 09:45 PM
rlcyran's Avatar
rlcyran rlcyran is offline
Default Cork Gasket
I’m looking to replace my cork gasket on my cub 1450. My question is there a certain amount of torque when I retighten the bolts. So I don’t flatten it or much?
Old 06-06-2025, 08:40 AM
Graflex45's Avatar
Graflex45 Graflex45 is offline
I did the same job on my 1450. Look in a coy of the manuals on here for the recommended torque specs for the bolt size they are, I don't remember specs like that I just consult the tables if I have to (same with my car's rims, I wrote it in the manual on the rotation diagram so I don't have to remember!)
You don't have to worry about over-flattening the gasket because the pump and differential mate together on flat metal surfaces the bolt holes are on, the cork gasket just fills a joint that isn't directly bolted.
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller
70- 38in deck, 42 inch deck
