Old 06-28-2025, 11:49 PM
Evenflow28123 Evenflow28123 is offline
Default Faster
Hello, I have a 2012 cub cadet rzt50 model 17yi2acp056. Id like to make the mower faster. I just did a complete deck rebuild on it. Changed all of the spindles and pulleys along with the deck belt. I replaced the Transmission belt as well. When I was putting the deck back on I screwed the threads up on the deck lift hangar. So I ordered a new one of them. I did not replace the pto pulley or the drive pulley. I am going clean the carb when I get the hangar in as it was a long day redoing all the pulleys and such on the deck. I removed the screws already that control the forward limit of the handles that didn't do much. The hydro trans was whining a bit so I put some more 20w50 oil in there. I do not want to buy new hydros so if I can do any upgrades without doing new trans id appreciate it
So my questions are;
What can I do to increase speed?
What can I do to increase rpm so blades spin faster and don't bog down?
Thank you
Evan
Old 06-29-2025, 07:48 AM
green407's Avatar
green407 green407 is offline
Could get rid of the governor on the engine and run it a WOT till it throws a rod. That would make things faster for a bit.
128 X 2, 129, 149, 1250, 1450 x 2
Old 06-30-2025, 09:41 PM
Sergeant's Avatar
Sergeant Sergeant is online now
Bigger drive Tires if they fit will Increase speed By Maybe a 1 to 2 Mph Faster
All I can think of is Tim Allen in Home Improvement when he put the motorcycle engine in the lawn tractor and hit the gas, and it went backwards.
I sure hope Your significant other took out a bigger Insurance policy on you
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 06-30-2025, 10:42 PM
Ol’ Autocrosser Ol’ Autocrosser is offline
Perhaps the simplest way to increase your ground speed would be a simple as changing the size of the sheaves (pulleys) between the engine and the inputs of your hydrostatic drives.
You likely will not find the parts from Cub without a lot of research, but you can likely find what you need from any industrial equipment supply store like Graingers or IBT (Industrial Bearing & Transmission). They all have good mail-order capability so you can search online.
I don’t know the exact layout of your machine, but all zero turns drive a hydro for each wheel. You likely have a single V-belt on the motor output haft driving a belt that runs to the input sheaves of both hydros. My 50” ZT1 has about a 4” diameter sheave on the motor that (I think, because I haven’t crawled under it to verify) drives both hydros.
Going from a 4” pitch diameter motor sheave to a 5” will increase your ground speed by 25%, and that’s a lot! It will also REDUCE your torque to the wheels by 20%, so if you have a lot of steep hills to climb, consider that as well).
Depending on the belt tensioner setup, you may or may not need to get a slightly longer V-belt as well.
You will need to know the motor shaft diameter and keyway size, the belt width (should be in the belt description in your parts list), either the Pitch diameter or Outside diameter of your motor sheave, and the WIDTH of the motor sheave hub (since there are almost certain to be multiple sheaves on the motor shaft - the second to drive the blades - and you want to keep everything lined up.
If you can find a suitable sheave - they’re relatively cheap - this is likely your lowest-cost solution.
Caution, don’t get carried away with speed - the small diameter tires on these mowers will accentuate any roughness in your yard - you don’t want a bucking bronco!
Good luck to you, and please let us know what you decide to do - and how it works out!
