Old 07-21-2025, 12:01 PM
BILjamSau32 BILjamSau32 is offline
Default GTX2100 Drive
I have a 2012 GTX2100 that sheared off 3 of the 4 bolts holding the drive shaft to the crankshaft. I removed 2 of the broken bolts but am having a "challenge" with the third. Before I get more aggressive, I thought that I would check to see if I could find a replacement for the part. But, can't find the part in any parts diagram. Suggestions?
Old 07-21-2025, 05:47 PM
I didn't see it on the parts lookup either. I went and pulled a 3000 series machine up with a Kohler engine and did a search on that number (24-029-12-S). Is this what you are looking for?
https://www.amazon.com/CUB-CADET-KH-.../dp/B09881ZY26
Old 07-21-2025, 05:57 PM
Dang, has anyone used these Chinese knock-off drive barrels?
https://www.amazon.com/759-3764-Repl...28&sr=8-3&th=1
Old 07-21-2025, 08:01 PM
Ozcub's Avatar
Ozcub Ozcub is offline
I replaced mine with genuine but I do not think the material is super high tech so if doing it again I would use the cheapies
Try this part number 719-3096 Adapter Engine , that Amazon part is the same
Oz
Old 07-22-2025, 06:45 AM
Todd I just put a set in my JD yard dumper that has a lengthened 2000 series drive line. The old set had gotten hard and they crumbled. Can't say how long they will last and this thing doesn't get much use.
