Old 08-17-2025, 12:35 PM
NoSubstance NoSubstance is offline
Default Charging Problems
Good morning
Awhile back I posted that I thought my battery was being discharged during operation. After more testing the charging system only puts out about 12 volts instead of about 13.5 that I have read it should produce. I have grounded the starter/generator and get a noticable change in load on the engine, but voltage going to battery does not change. I have tried two different Voltage Regulator and see no difference between the two.
Is my generator failing or should I purchase a new voltage regulator?
Is there a way to test voltage at the generator or at the regulator?
Old 08-17-2025, 01:05 PM
green407's Avatar
green407 green407 is offline
This guy has several videos about testing the starter generators, and voltage regulators, and how to adjust them.
https://www.youtube.com/watch?v=W8C26XOFAhM&t=58s
128 X 2, 129, 149, 1250, 1450 x 2
