hi i am a new cub owner i inherited what i thought was a 126 but as i ran the serial number i tguess its a 86 and the motor dosnt have a tag on it but it says 14hp kohler anyways heres some pics of the tractor i popped the head off and found burnt head gasket it ran but not right
Looks like a 108 that got an engine transplant.
128 X 2, 129, 149, 1250, 1450 x 2 |
what makes u say that the seriaL NUMBER COMES BACK AHN 86
You got a wide frame.... the 126 was a narrow frame. Looks like you got a mish mash of Cub Cadet tractors put together.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Definitely not a 126, someone put the wrong decals on it. An 86, 108, and 128 are all the same tractors, only difference being the engines, 8 hp K181, 10 hp K241, and 12 hp K301. It most likely is an 86, and someone put a larger engine in it, a 14 hp K321 would be a direct fit, but they never came from the factory in a gear drive tractor. Now, if your serial number is on the transmission, it is possible that someone swapped that out with one from another tractor. If that’s the case, they most likely didn’t change the tag, and there is no way to tell exactly what your tractor started out as. It is definitely an 86, 108, or 128 though.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
Something is VERY STRANGE about your engine or else your 2nd picture is reversed. It shows your carb set up on the driver's RHS and your exhaust exiting the driver's LHS. Hmmmm....but your first picture shows the carb on the correct side. Cornfusing???
3rd pic reversed also. Keyswitch & solenoid on wong side. Or it's a British Cub?
