Old 09-13-2025, 03:30 PM
CVACUB CVACUB is offline
Default Which steering shaft
So I’m about to start rebuilding my steering and when I look at parts there are certain parts that say steering shaft xxx and the same part for steering shaft xyz. Now the top of the shaft has 2 metal dowels that fit into the steering wheel and the steering shaft so which one do I have so I can order the correct parts. It’s a 122 CC
Thanks in advance
Old 09-13-2025, 04:26 PM
ironman's Avatar
ironman ironman is offline
No offense intended and it's probably me, but your statement or question make no sense to me.
Old 09-17-2025, 09:30 PM
dale c. dale c. is offline
the steering wheel and shaft have splines unless someone has rigged it
Old 09-21-2025, 03:21 PM
Yes someone has rigged it. They drilled the steering wheel and the steering shaft and put in two 1/4 inch pins I guess to stop it from slipping
