Old 10-01-2025, 06:11 PM
jfinney's Avatar
jfinney jfinney is offline
Default 2072 Blowing fuse
Good evening. I have a 2072 which I use for cutting grass and plowing snow with. Mid summer I was cutting grass and the PTO shut off. Tractor kept running, but I shut it down to check things out. It then wouldn't start again. I towed it back to the barn and found that the fuse blew. So, I bought some new fuses. when they came, the tractor started right up and I resumed cutting grass. After about 5 minutes, the PTO shut off again and the tractor kept running. I drove it back to the barn and shut it off. Fuse blew again. I am not great with things electrical. I do have and no how to use a multimeter. How would I check the Indak PTO switch to see if that is the problem? What else should I be looking at? I appreciate any assistance you can provide. I'd like to get this fixed before the leaves start to drop.
Old 10-03-2025, 03:12 PM
Sounds like your PTO may be going bad or you have a wire that is shorting to ground.
Here is the PTO checkout procedure listed in our technical section.
https://www.onlycubcadets.net/forum/showthread.php?t=30
Here is the wiring schematic for your tractor if you don't have one.
https://www.ccpartsnmore.com/cub-cad...ing-schematics
Old 10-04-2025, 04:58 PM
jfinney's Avatar
Thanks for the information. I will try to have a look at it tomorrow. I did have the service manual with wiring diagram for the tractor, thank you. My PTO switch only has 5 prongs though, whereas the diagram shows 6. In the diagram, if it says in the "off" position "C+D" does it mean there should be continuity between C+D in that position? I took the switch off the tractor, so I can check for continuity, but not voltage at the moment. I appreciate your help. Can the PTO themselves be rebuilt, or would I be looking at buying a new one if it is going bad?
Old 10-05-2025, 08:28 PM
Yes, C & D will be closed when the switch is in the "off" position for the start circuit to work on the tractor.
New bearings can be installed in the PTO's but that's about it. If you need a new one this is the place to go. I would call them and see if they can help you out.
https://xtremeope.com/?srsltid=AfmBO...PzMHPHl2XVyJNJ
Old 10-08-2025, 05:22 PM
jfinney's Avatar
So, I picked up some fuses today. I disconnected the harness to the PTO, and when I turned the switch on, all gauges and lights turned on. When I started the tractor, lights and gauges all turned off, and when I checked the fuse, it was blown. Immediately after the fuse blew, I checked voltage on the battery and it read 12.9 volts (I don't think to check before I started the tractor). Right now, about an hour later, it reads 12.78 volts. So, I'm assuming the fact that the fuse blew immediately upon starting the tractor, without the PTO connected, means the PTO likely isn't the problem. Could it overcharge quickly enough to immediately blow a fuse, it is something else going on? Also, can you tell me what the pay is in this picture? Is it a voltage regulator? Thanks again for your help.
Jason
Old 10-08-2025, 05:25 PM
jfinney's Avatar
Not sure what I'm doing wrong. I'm trying to post a picture from Amazon photos
https://www.amazon.com/photos/shared...YXElxgYmuPktB-
Old 10-08-2025, 06:00 PM
Billy-O's Avatar
Billy-O Billy-O is online now
If you eliminated the PTO and still encounter blown fuse, you likely got a short somewhere. Time to break out the meter and start tracing the short starting from the fuse that's blowing. I would be looking for continuity to ground with the fuse out. The key switch could be the culprit, but keep in mind that the key switch grounds the magneto at "off". I doubt the lights could be the problem since it has it's own fuse.
Plow blade
#2 Cart
QA36 snowthower
Old 10-08-2025, 07:52 PM
jfinney's Avatar
Thank you for your response. I have to admit my knowledge of electrical is limited. How would I check for continuity to ground?
Old 10-08-2025, 08:21 PM
The owners manual says it only has one fuse but the schematic shows 2. The manual says it should be a 20 amp slow blow.
Looking at the pic of my 1872 (same tractor) I only see one fuse in the dash tower.
I would look real close at your headlight wiring for any shorted wires. This can be a problem area on the 82 series.
If no issues are found there I would do as other say and use a continuity meter and check for a short circuit.
I would remove the + terminal cable on the battery and place one lead on the cable you just removed, make sure your fuse is good and place the other lead of the meter on the battery negitave terminal. If your meter has a beeper I would turn that on. Now, turn the key to the "lights on position" and see if your meter is beeping. You will read resistance of you lights in this position but if it is 0 you have a short. Turn the key to the run position and start moving wires around and see if your meter starts beeping showing that you have a short.
Good luck and let us know what you find.
Old 10-08-2025, 09:14 PM
jfinney's Avatar
Thank you. Yes, I only found the one fuse in the tower. I bought 20amp show blow fuses. Thanks for the heads up on the lights. I'll check that out.
