Go Back   Only Cub Cadets > The Trading Post > For Sale
Old 01-19-2026, 02:37 PM
chris-neises chris-neises is offline
Default IH Cub Cadet Snow/Dirt Blade $300
This blade was removed from an International Harvester Cub Cadet 108, and I believe it will fit all Cub Cadet Wide Frame garden tractors. It is in very good shape and is ready for winter. This garden tractor dozer blade is a heavily built unit which can also be used for grading. Slip-plate graphite coating has been applied on inside of the blade and wear shoes to prevent material buildup.
Local Pick-Up only, (Anoka, MN) as it is a very heavy item. Can help with loading.
Text: six one two 799 forty-five ten
Price: $300
Old 01-21-2026, 08:40 PM
The rails of the subframe appear to be set for a NF (narrow frame) tractor and not a WF (wide frame) one.
Old 03-08-2026, 07:38 AM
I also thought that originally. Not sure what it was originally designed for, but it did fit on a 108 wide frame, and would be heavy to lift without the spring assist.
Old 03-08-2026, 09:33 AM
Appears to be a " modified & made to fit" assembly.
