Old 02-20-2026, 06:31 PM
jfaison jfaison is offline
Default Seal Breather Tube Gasket Cover
I am working on my 782 with a KT17. I am replacing the breather tube and have a question. Where does the red seal go? It was loose under the cover when I removed it. Also, do I need to add a sealer to the cover gasket? I attached an image.
Thank you.
Old 02-26-2026, 07:37 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Thank you.
Since no KT17 owners chimed in....
I dont have a KT17 so I'm not sure of the red seal.....but by looking at the engine diagrams Cub Cadet Parts &Service link above, that red seal is maybe for either the air filter housing assembly or the breather assembly...... it appears it slides over the threaded rod that is used to hold/attach the assemblies together. It must be properly placed between two parts also on this rod.
I would hazard a guess.... someone had taken the air filter assembly apart and dropped the red seal down the breather tube.
Plow blade
#2 Cart
QA36 snowthower
Old 02-26-2026, 08:40 AM
Billy O is correct the red seal goes over the rod. You should have
a gasket for the cover itself otherwise it will leak. I always put a
thin layer of sealer on the gasket and I mean so thin you can't
hardly see. But I am a bit of an overkill guy. I imagine a person
could make a gasket and be just fine but you will want one.
Ken
Old 02-26-2026, 10:03 PM
The neoprene red bushing does indeed go over the stud in the breather between the covers as mentioned, it keeps the oil vapor from seeping around the stud and out of the top cover making a very slow, but steady unsighty wet area overtime.
Old 03-05-2026, 07:57 AM
DSarow DSarow is offline
O.k,I some how thought when I bought my 125 and that part was missing,the cover was wrong side up,leaking and warped that it was a spacer to keep the cover from being over tightened.Thanks I then proceeded to buy and study all the manuals I could find and join these two cub forums to learn many things from all the knowledgeable guys.There were a few other things I found,but we're good now
Old 03-17-2026, 10:17 PM
Thank you for the replies. You confirmed what i thought but i did not know the reason why.
