Hi all,
I recently picked up a 3 point lift for my 127 from a forum member. I was also fortunate to have a really nice brinly adapter fabricated for me by another member (cubs-n-bxrs). The only piece I am missing is the upper lift pin to be used with a plow, not tiller. I have a piece of 1" round stock, but I'm not sure how long it should be, how much should protrude out from the casting, and the proper hole placement....would anyone have one around, and be able to give me some quick measurements? Thanks, Jeff (teet)
CCC 1211 71 127 ![]() 102 122 1962 Original |
Four of the ones I measured are about 3-1/4" with the hole being 2-1/4" from the end of the casting the other one was 4-7/8" with holes being at 2-3/4" and 4-1/4".
For maximum movement of the sleeve hitch adapter I would think that you would want the hole in the pin to be directly above the hole in your sleeve hitch adapter.
![]() Jeff (teet)
