Old 05-24-2026, 05:28 PM
wyldewon wyldewon is offline
Default Starter Drive Gear
I'm working on a K321 in a 1450. When I turn the ignition key to crank, The starter Drive Gear only comes out a little and never engages with the flywheel.
I removed the drive gear from the starter shaft and noticed I can spin the gear in both directions while holding the inner hub with the spiral splines.
Shouldn't that lock up in one direction?
Any help would be appreciated.
Tags
drive, gear, k321, starter
