Old 05-25-2026, 05:47 PM
cwthompson2000 cwthompson2000 is offline
Default Blades won't engage
Was mowing and all of a sudden the blades stopped. Tried starting them a few times but they won't spin.
Removed the deck covers and cleaned pout all the grass clippings and found a broken spring on the top of the deck. Still hooked on one end but the other end is broken off. Can't see where it goes. The belt is loose as well. the spring must hold the tension on the belt.
Need to replace the spring but will that cure the problem?
Best place to order a new spring...???
Thanks,
Chuck
Ultima ZT1 50"
Old 05-31-2026, 09:59 AM
stcyrmb1 stcyrmb1 is offline
NOT a pro on these matters, but had similar issue w/60" Pro Recon. ... certainly where I would start
Mark
Jones, OK
Old 05-31-2026, 10:30 AM
ironman's Avatar
ironman ironman is offline
Any help....
