Old 07-12-2026, 03:45 PM
Rick-147 Rick-147 is offline
Default Hydro Control Mechanism
My 147 hydro control became rusted solid. I got it out and resolved that issue, and now in the process of putting it back together. My question is, with the control assembly disconnected from hydro, how much drag should there be at the lever...how tight should that 1-1/16 friction nut be?
Thanks in advance!
Rick
Old 07-12-2026, 07:18 PM
mortten mortten is offline
From the manual.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 07-12-2026, 08:30 PM
you can browse the manuals section to find your model.
go here and see how it is suppose to be .
https://www.onlycubcadets.net/forum/...splay.php?f=19
Up to 534 and counting...
Old 07-13-2026, 11:52 AM
Default Thank you Mortten, but now stuck on step 2
Originally Posted by mortten View Post
From the manual.
Daaah, I have the manual and did not even think to look.
Thanks for that.
Now... can anyone explain page 2-63 step "b"... "Place a small wedge or key stock of proper size between the mounting bracket and the adjusting nut. Refer to foldout at back manual."
I don't understand the purpose of this step?
Rick
Old 07-13-2026, 11:55 AM
Default Thanks for the link!
Thank You for the reference.
Rick
Old 07-13-2026, 03:33 PM
ironman's Avatar
ironman ironman is offline
They are saying "you ain't gonna get no wrench on this nut, so find something that fits to jam it in place to keep it from rotating."
Then when you move the control lever you will either loosen or tighten the nut's pressure on the friction disc's.
Old 07-14-2026, 01:19 PM
Your brilliant Ironman! Thank you!
Rick
Tags
147, friction nut, hydro control
