Old 07-13-2026, 07:39 PM
Borjawil Borjawil is offline
Default Hydro gear swap - what models?
Cub cadet z Force 48"
model 17AF3AGV010
My issue is that the pump cylinder and motor cylinder blocks are scored heavily. I could turn them down on my lathe but I'm not sure how far I can go before they would be an effective or not work correctly. I can get the center section and both cylinder blocks for approximately 300 or so. Which isn't out of the question. But if I can find a used hydro gear that is working for less I'd like to go that route
Hydro gear zt-2800 part # zh-jcbc-3k2c-2ll1
Superseded to zh-jcbc-3k2c-2pl1
The superseded number searching in Google brings me to websites selling them with another part number as well ZH-JCBC-SK2C-2PL1
Trying to find listings for a used one proves difficult as they don't have the exact part number listed. So was trying to see if anyone new what other models used these part number, so I can search for mowers being parted out.
Old 07-14-2026, 11:29 AM
CubDieselFan's Avatar
How old is the mower and how many hours does it have?
Old 07-16-2026, 03:55 PM
I'm not sure how that's relevant to my question.
As stated the pump and motor cylinder blocks for the hydro gear are toast. The center section is also likely done.
Old 07-16-2026, 04:23 PM
It just may not be worth it to invest a lot time and money in the mower if it has a lot of hours.
Old 07-16-2026, 05:35 PM
gO HERE, AND PUT IN YOUR MODEL NUMBER. SELECT WHICH ONE, RIGHT OR LEFT FROM THE PARTS BREAKDOWN. THEN USE THE PART NUMBER TO LOOK UP WHAT OTHERS USE THAT PUMP.
https://www.cubcadet.com/en_US/conte...artstream.html
Up to 534 and counting...
