Old 07-22-2026, 04:25 PM
TexasBBQ TexasBBQ is offline
Default Oregon G6 mulching blade
Been looking at the Oregon mulching blades. On my mower I need qty 3, 17” blades with 3/4” mount hole. I would like to get the G5 blade since it’s thinner, but they don’t make it with that mounting hole. They do make the G6, but I’ve heard because the thickness of that blade you need more than typical horsepower. I’ve got a Kohler 22 hp.
Anybody have the same set up with the G6? If so what were your results?
Old 07-22-2026, 04:58 PM
ATernus ATernus is offline
Not exact same setup, but I've ran the G6 blades on previous and current mower without issue. Love the gator blades. Both mowers are green, and one with 62" deck, current with 60" deck. 21" length of blade on current mower, and leave a clean cut, and only leave a windrow if i wait too long between mowings. old mower was 24hp Kawi, current has 25hp Briggs.
Old 07-22-2026, 08:28 PM
My mower is 48”. I was informed by Oregon that there is no HP specification for the G6, but a rule of thumb for this blade is 24-25Hp+. So, my mower is obviously few Hp below the minimum.
I’m curious if anyone that’s basically “under “ the minimum is having success or not.
Old 07-22-2026, 09:21 PM
CubDieselFan's Avatar
I ran the Gator blades for years. I switched to high lift blades last year and I get a better cut with these blades.
Old 07-23-2026, 12:35 PM
Per the Oregon spec the G5 and G6 are high lift. What are you running?
Old 07-23-2026, 01:00 PM
I am using the ones in this thread.
https://www.onlycubcadets.net/forum/...ad.php?t=63098
Tags
mulch, oregon g5, oregon g6
