Old 08-12-2026, 12:01 AM
therock therock is offline
Default Z Force 44" Pump Failing, Cannot Find Replacement
Its replace, repair, or sell, part out or put to rest my old friend.
Any one know of 310-2400 pumps available. Cub numbers 01008192 (Left) and 01008923 (Right)
2003 ZForce 44" 23HP B&S
Old 08-12-2026, 09:36 AM
This is from a google search:
(I know nothing of these mowers)
updated part number 01008192P, and 01008193.
If you do not want to buy a whole new transmission unit, you can fix common issues by ordering specific sub-parts online:The Wheel Hub: If your axle spins but the wheel does not turn, you may have a broken hub assembly (commonly ordered as part number 72073).The Seals: For oil leaks, you can find a 70553 Overhaul Transmission Seal Kit on Amazon.The Return Spring: For tension tracking issues, you can use a 51833 Extension Spring on Amazon.
Old 08-12-2026, 07:22 PM
PandPsmallengines has them- they are not cheap
Old 08-14-2026, 11:42 PM
Thanks Guys, I'll get back when all said and done.
