Old 09-14-2010, 05:58 PM
CC Rider's Avatar
CC Rider CC Rider is offline
Default Oil Pan Leak
It's been in the 60's for a week now here in Vermont which made me realize I had cub things to get done before winter. Number 1 was an oil leak on my 129 loader. I've been under it twice and could see it was bottom end ....... front and rear seals were dry after cleaning everything off so I went and got a pan gasket and went to work. After getting the motor on the ground and the pan off I realized the gasket was in great shape but there were pieces of metal in the pan.
Seems the PO mounted the motor with the wrong bolts (to long) and they broke the casting off the top of the bolt holes inside the pan on the 2 front bolts. Luck had it that I had an extra pan on hand so it was an easy fix. Well the problem was easy ....... getting the motor out and in on a cub with a loader, by yourself is a ROYAL PAIN!
Tom
CC's - 108, 122, (2)124, 149, 1320
Old 09-14-2010, 06:20 PM
NiasNeb's Avatar
NiasNeb NiasNeb is offline
Default Fel
Do you have the side panels on yours? I have them on mine and it looks like I'm going to have to take apart some of the loader to get them off. I might just leave them off when I figure it out. If you didn't already know...I just got this one and I wasn't part of the "attach the loader to it" process. It looks like they mounted the support bracket to the frame under the panel with a nut and bolt but I just don't see how to get to the bolt...yet. I guess I have to get under it and look up.
Nias Nebraska
Old 09-14-2010, 06:25 PM
Sminkey
Guest
Posts: n/a
Default Winters a comin
Glad you got your 129 all fixed, I've been in the same mode. Just picked up a #1 tiller this afternoon, but have been getting the 71 ready to hook up the cc36 blower. Need to do some work on the auger, it's a bit chewed up, but with some more practice welding I should be able to make it decent.
Old 09-14-2010, 06:49 PM
CC Rider's Avatar
NiasNeb
Nope .... No side panels / see pic. My grief was having to put it up on blocks to drop the front axel, to get the front mounting bolts out. Good Luck with yours.
Sminkey
Winters coming fast, half my leaves are down already so good luck with your blower.
Tom
Old 09-14-2010, 07:57 PM
A 129 doesn't have side panels.
Old 09-14-2010, 07:59 PM
Woop! CC Rider has faster fingers than I do.
Old 09-15-2010, 08:27 AM
I know that feeling! I ended up taking the arms (for a lack of a better term atm) and bucket off when I pulled my K241. Taking it off was no problem, but putting it back on and getting it lined back up so I could reinstall the pins sucked!
Old 09-15-2010, 08:28 AM
Once you figure how to get them off put them back on it will help your motor run cooler. You can do it!
Old 09-15-2010, 12:28 PM
NiasNeb's Avatar
Default Panels
Did I read that right? Having the panels on makes the motor cooler?
Nias Nebraska
Old 09-15-2010, 01:02 PM
Yes they are made to run with the side panels. It improves air flow around the motor so yes it runs cooler.
