Old 05-12-2009, 07:56 AM
rickv1957 rickv1957 is offline
Default RPM Trouble Cub 2155
Hello,
My cub starts mowing fine at full throttle.However after it warms up, the rpm's will drop quite a bit for no reason.Thanks for any help.
Rick
Old 05-12-2009, 09:14 AM
diesel_nut diesel_nut is offline
Gas cap vent OK?
1872 (SOLD) will live to regret it
GT2554
Old 05-12-2009, 09:58 AM
murphycc
Guest
Posts: n/a
Can you be more discriptive? I can think of several posibilities.
Scott
Old 05-14-2009, 07:13 AM
Default Thanks For The Reply's
Hello,
After about an 1/2 hour of mowing,the engine rpm's will suddenly with no reason drop to about 1/2 or 3/4 full throttle.As though something pushed my throttle lever back.I then have to mow the rest of my yard taking smaller cuts.How would I check the vent cap,maybe leave the cap cracked loose the next time I mow?
Thank's Again,
Rick
Old 05-14-2009, 02:47 PM
Allow the cap to be loose enough(or completely off if possible) to allow it to vent directly and try it. That will eliminate one easy-to-fix situation. Kinda doubt that is it because of the length of time it takes, but you never know.
GT2554
