Old 10-06-2010, 08:49 AM
drhntrrmw's Avatar
drhntrrmw drhntrrmw is offline
Default Narrow Frame Plow Skids??
Does anyone know where to find plow blade skids?
Rob
Old 10-06-2010, 09:16 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Rob,
Check our sponsors - especially here: http://ihcubcadetparts.net46.net/
Old 10-06-2010, 09:33 AM
Terry is right, just checked and they are listed here. About half way down you'll see them.
http://ihcubcadetparts.net46.net/1_2_Products.html
Old 10-06-2010, 09:59 AM
T-Mo's Avatar
Thanks, Duke. I thought I saw them there, but I can not access Mark's site from work - I get the dreaded "Access Denied" thingy from our companies' security. Don't know why - some thing's there that triggers it.
Old 10-06-2010, 12:14 PM
drhntrrmw's Avatar
Thanks, I knew someone here would help me...
Old 10-07-2010, 06:06 AM
cdlong's Avatar
cdlong cdlong is offline
This guy has them also.
http://www.xtrememotorworks.com/Part...tm#Snowblowers
Old 10-07-2010, 09:30 AM
I made a pair from a broken truck leaf spring I found on the road.(almost hit it with my tire)
Just heated it a bit to curve them up on either end and welded it to the worn off stub.
works great!
Old 10-07-2010, 05:42 PM
Flatbedford's Avatar
While we are talking plow skids, can somebody explain to me why to use them. I just bought my 125 in April so I haven't plowed any snow with it yet, but why use th skids and not let the cutting edge ride right on the ground? It seems to me like using the skids would leave more snow on the ground to then drive over and either lose traction or just pack it down and make ice. Am I missing something here? I read that some use the skids for plowing a gravel drive, but what about blacktop?
Steve,
Former multiple 149 owner.
Old 10-07-2010, 07:09 PM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
you have the answer right there, if you have a gravel drive or uneven then you would use the shoes to keep from plowing gravel and dirt. same goes for a snow blower. now it you have a blacktop or cement drive then you would want to go as low as you can, it will be your choice if you want to wear out and replace shoes or the wear edge on the plow. as far as traction goes you are in snow and ice so chains are your first best ways to get traction then weight then tire tread. of course all i have said is just my opinion, take it for what it is.
Old 10-07-2010, 10:07 PM
If you use skids on a blacktop drive, you will have an ice rink.
