Old 10-06-2010, 02:10 PM
TheSaturnV's Avatar
Default Voltage Regulator Photo: What is the wire-wrapped rod?
Didn't know quite where to post this, but this VR looks like the type used on older IH Cubs. What is the jumper type non-metallic, wire-wrapped rod that connects across two terminals on the bottom?
Perhaps a fuseable link? It is somewhat easily removed by opening the clamp ends. I did some damage to the wire, and had to re-wrap with new wire that is just a hair thicker. I'd just like to know what this piece does, and if my repair will suffice.
Thank you.
Old 10-06-2010, 02:11 PM
It is a "wire wound resistor".
Old 10-06-2010, 02:39 PM
TheSaturnV's Avatar
Okay, thanks. Being a resistor, I wonder just how crucial the wire thickness, type and number of winds will end up being. I can't simply fire it up and test it right now, since the tractor is being built back in a restoration effort. I'm just now putting the electrical back in, and probably a few days away from test-firing the motor.
I appreciate the input.
Old 10-06-2010, 03:50 PM
Wire wound resistor are more precise than carbon core. I don't know the original value of that resistor, but I would say it would precisely designed.
Old 10-06-2010, 04:07 PM
TheSaturnV's Avatar
I see.
Well it's either plunk down $50ish and replace it, or try to repair it and expand my wee brain a bit. So, I've put on a thicker wire, with a guesstimated number of wraps. I've likely lowered the resistance at this point. I'll have to wait til I get home to see just what I my be sending more juice to.
Thank you Sir.
Old 10-06-2010, 06:31 PM
This is a Wiring Diagram of a Typical Circuit.
As you can see, there is a Resistor (in blue) to ground within the V/R. That is what your issue is about.
Old 10-06-2010, 08:11 PM
TheSaturnV's Avatar
Great, that's really helpful info. Thank you Roland.
Old 10-07-2010, 10:48 AM
Hubman's Avatar
Hubman Hubman is offline
Curious , the value of that Resistor ? It must be something small , but large wattage . Anyone have an idea of the Value . My guess 2 -4 ohms
Edit : I just checked a new V/R I had on shelf . It reads 54.8 ohms across the resistor .
Old 10-07-2010, 10:10 PM
Tom S Tom S is offline
You can't wind the resistor with any old wire. It is a special wire.
Old 10-08-2010, 12:37 AM
pulse301 pulse301 is offline
Are there not any markings on there that tell you the specs of it? I always remember looking at a chart for color codes on ones I used on my "learn to solder" kits that i had as a kid. If there are any markings on it you might be able to use it to just replace the resistor itself.
- Dusty
http://ihcc123.blogspot.com
