Old 10-12-2010, 10:17 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Default Separating a Blade from the frame???
I'm picking up a NF front blade this weekend. Problem is, I don't want to rent a van again after renting two this past weekend, and it's a long ride so it'll kill me.
I know it'll fit in the wifes car....if I can separate the blade to slide it next to the frame.
What does the pivot pin look like?
Can it be removed....or atleast grind the head off and replace with a new pin?
I can make anything to factory spec...but I need to know if I need to bring an electric grinder with a stone disc.
Will that work?
Being a 3-4hr round trip, I can't take a look/see before hand.
Fly Fishing is not a sport...It's a way of life.
Old 10-12-2010, 10:33 PM
All you have to do is remove the two cotter pins where the undercarriage meets with the main part of the plow.See Picture.You have to spread the undercarriage apart to remove it from the pins.Should fit no problem.
Old 10-12-2010, 10:39 PM
Hey eastonct124
Mine is a wide frame but i think the pivot point is the same. Does a picture help?
Old 10-12-2010, 11:09 PM
Prying the subframe apart is easier said than done. If your vehicle has a scissors jack, you're in luck...pull the cotter keys and spread the subframe apart with the scissors jack. That's how I take them apart and put them back together again.
Old 10-12-2010, 11:12 PM
Yes, thankyou both.
It appears to me that I can not only separate the blade from the mount, but also the mount from the frame.
I guess I'll just bring some side cutters. some wrenches (3/4" most likely), and a porta-power (to spread) to do the trick.
It's going in my wife's passat, with the back seats down.
Old 10-12-2010, 11:26 PM
Matt,
I like the jack Idea.Did the crowbar thing also,gotta watch your fingers
Old 10-14-2010, 11:24 PM
When the crowbar slips off and your hand hits something in the vicinity of your work area. BTDT and been using the jack ever since.
