Old 10-28-2010, 07:45 PM
JayBrd's Avatar
JayBrd JayBrd is offline
Exclamation Mayday, Mayday, Mayday!
Danger Will Robinson!!!
I washed the 682 Monday, a bit more than normal due to it being a bit dirtier than usual after doing some woods work. I did wash the top of the engine a bit more also, but still stayed away from the coil and plugs as possible. It ran as it always does (great) when I went to put her back in the shop. I even left it run a while to warm up and dry out a bit. Today I went to start her to do some storm clean up this aft and got nothing
It seems like no spark, would not fire even with starter fluid? I plan on pulling plug wires, fuses, ect and drying them out (if need be) along with checking for spark. I am not overly familiar with the twins, so any ideas on what else to check for?? If anything I am planning on putting a heat pad under the hood over night to keep it warm enough to maybe dry it out also.
Kind of stumped on this one
Jay N.
Eau Claire, WI
RED 82 Series...
Old 10-28-2010, 08:15 PM
Mizar N68X Mizar N68X is offline
Run a piece of sandpaper between the points.
Likely a small amount of oxidation from the water.
Old 10-28-2010, 08:48 PM
My 982 did that after I washed it. I let it sit in the garage a few days and let it air out and it was fine. Mizar is probably correct on the moisture. I was told never ever to use starting fluid in any engine...just my 2 cents.
Old 10-28-2010, 09:42 PM
I like your Motto "This ain't no hobby....it's an addiction"
Best part is that we won't end up like Lindsey or Charlie
Old 10-28-2010, 10:10 PM
JayBrd's Avatar
I am hoping that is just the case, I have a heater on it now and will pull the points cover in the morning if nothing works then. It's the only thing I can think of. The white needle is not moving with the key on either, but that could be a low battery
I have been threatened with rehab numorous times for cub addiction..:biggrin2.gif:
Jay N.
Eau Claire, WI
RED 82 Series...
Old 10-30-2010, 12:53 AM
JayBrd's Avatar
Well , after a few hours of chasing I finally got spark back. I checked the points they were dry and clean. The wires were a tad loose but nothing even after I snugged them up. I chased every plug, connector, and fuse and all were dry. I still had no hour meter movement or spark.. I took a bit of a break and came back and flipped the PTO switch on and off with the key on and low and behold the hour meter tripped on, so I turned it over and got spark back
Lesson learned I guess..
Jay N.
Eau Claire, WI
RED 82 Series...
Old 10-30-2010, 02:46 AM
Is the PTO a safety switch?
Got mine running too.
fouled plug & new points.
It was due for a new set of points they have been in my glovebox in the Kohler bag for 2 seasons........
Glad you got your Cub running JayBrd
Old 10-30-2010, 09:42 AM
Glad you got your 682 going, Jay!
