Old 11-01-2010, 07:34 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Default 1250 or 1450
I'm going to trade a JD LX176 for one of the two in the subject line. The JD will run good when started, but starting it is the problem. Very hard to start, if you can start it. I suspect the ACR is bad in it and it's part of the cam shaft and that's NLA from Kawasaki and JD. It also has the common hood problem of that JD era - broken.
Anyways I might trade it for either a 1250 or a 1450. Both would be projects. The 1450 is really rough looking - someone at one time tried to paint it red. It will run but has a noise in the engine. It's also missing the head lights, grille insert, tie rod and the deck is rough.
The 1250 is in good shape, cosmetically. It's also complete, but will require an engine rebuild.
Though I would like the hdyro lift of the 1450, I'm leaning towards the 1250 as it's in the best shape. Both will probably need an engine rebuild.
Who knows I'm change my mind and pull the engine off that JD and see if I can fix the ACR, but I would rather have one of those Cubs instead. Whatever I do, will require some work and money.
Also I'd been told about a 1450 and a 1650 that I might go see. Decisions, decisions, don't you just love it when you have options?:biggrin2.gif:
Old 11-01-2010, 07:59 AM
I know what you mean, Terry. You'll make the right decision!
Old 11-01-2010, 09:45 AM
I've got a 1250 and really like it. I too would like the hydro lift. So just do what I plan to do. End up with both models . Buy the 1250 now and fix it up, then locate and buy a 1450 later when $$$ allows. Yeah it will probably take me a couple more years to be able to get one, but then again, this yellow fever seems to be a life long affliction, so I have time on my side...
Old 11-01-2010, 10:23 AM
jmroy's Avatar
jmroy jmroy is offline
With all the problems the 1450 has you should be able to get it cheap. Trade for the 1250 and offer the guy a little bit of cash for the 1450 and then swap the hydraulic lift.
Old 11-01-2010, 10:51 AM
GERKS 149 GERKS 149 is offline
Just add the hydro lift to the 1250. That is what I am doing right now.
Old 11-01-2010, 01:57 PM
NiasNeb's Avatar
NiasNeb NiasNeb is offline
Default 1450
My 1450 made a horrible engine noise too...so I thought. It turned out to be a simple fix of replacing the motor mounts. There's a bare spot on the top where it was hitting the side.
Nias Nebraska
Old 11-01-2010, 02:34 PM
Noise could also possibly be the balance gears???
Old 11-02-2010, 11:10 AM
T-Mo's Avatar
The engine noise in the 1450 could come from a few places, but it's best to think the worst and be pleasantly surprised than to think the least and be "shock". So I'm thinking rebuild until I see otherwise.
Old 11-03-2010, 09:21 AM
Good line of thinking Terry.
Old 11-04-2010, 01:53 AM
hillbilly hillbilly is offline
before you send your lx on its way "hard starting" check the lash on the valves make sure its .004" if it grows beond that the acr will not properly work. A tractor that starts easy is always worth more than one that sorta starts. (this lash check really applies to all brands of engines)
