Old 11-03-2010, 09:18 PM
mhl380 mhl380 is offline
Default ? for Matt G or anyone
i have a 1862 when you turn the lights on the amp will flash
and if you turn on the pto the light will come on and stay on
how do you check to see if the alt is working and putting out the
corrrect voltage or amp's i did have the magnets on the flywheel
come off and i repaired it it did not damage the coil that i can
see. what wires do i check coming from the voltage regulater
and what should i see for amp's or volts any info would be
helpful thank's. Rick
Old 11-03-2010, 09:49 PM
sorry i meant the stator not the coil. Rick
Old 11-03-2010, 09:59 PM
I'd start by putting your multimeter on the volts setting across the battery terminals. You should be getting about 13.5V with the tractor running.
Old 11-03-2010, 10:10 PM
thank's Matt i will check that if it is the correct voltage
where do i go from there. Rick
Old 11-07-2010, 07:03 PM
just checked the voltage across the battery post im getting
12.50 volts any ideas thank's Rick
Old 11-07-2010, 07:19 PM
That's too low...I would check the output of the stator...should be about 28VAC across the two terminals coming out of the stator.
Old 11-07-2010, 07:32 PM
i will check that in the morning and check back thank's for the help
Matt. Rick
Old 11-07-2010, 07:42 PM
Matt what two do i check on the plug is it the plug going to the
regulator
Old 11-07-2010, 07:57 PM
It'll be the two coming out from under the flywheel. I'd suggest downloading the service manual from Kohler's website. It explains some of this and has troubleshooting guides in it.
Old 11-08-2010, 09:40 PM
Matt i found my problem fly wheel magnets are not in the right place
a while back i found them all loose so i cleaned them and put
them back in not knowing they go in a certian way Rick
