Old 11-10-2010, 05:40 PM
kenny9815 kenny9815 is offline
Default 123 hydro problem
My 123 is leaking fluid, I changed the suction line didn't fix the problem. I noticed also that the brakes arn't working either. I changed filter and fluid but still no brakes. Can someone let me know whats going on? I found a snow blower with all the mounting hardware and would like to use the 123 for blowing snow this year. I do have a 125 hydro would that tranny bolt into the 123.
Old 11-10-2010, 05:57 PM
The leak is probably the gasket between the hydro pump and transaxle. Common problem. If not that, one of the trunion shaft seals or the input or output shaft seal. The brakes probably need adjustment...they aren't going to magically fix themselves. The 125 rear is the same, but you can easily fix the one that's in there now.
Old 11-10-2010, 07:35 PM
Default 123 hydro problems
Is there a dissemble and fix diagram on this site? That would really help me out to repair the problem. I don't have a manuel yet for repairs. I was also wondering about how to do the maintance on the gear box for the snowblower. Don't know what it takes for fluid or grease and where to put it in at. Thanks for the help
Old 11-10-2010, 07:40 PM
Service Manual
