Old 11-12-2010, 06:42 PM
cbrown cbrown is offline
Default Battery not charging
I have a cub 102 and just wondering what i need to check or replace that is causing my battery to not charge while running which in turn is causing a dead battery after a few hours use. Thanks in advance!
Old 11-12-2010, 07:29 PM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
well there are a few things to check, wire connections, voltage regulator, starter generator,ground for the voltage regulator. i would say pick one of the above and go from there. is your voltage meter working?
you will need a meter to check output of starter generator, i had nothing showing on volt meter but would get a charge when moving regulator around once motor was running so traced it down to a bad ground from strap to case on the voltage regulator to frame. just a few places to start looking.
