Old 11-18-2010, 08:30 AM
samspops samspops is offline
Question more stupid questions....
Hi ALL,
I have a couple more questions that all of my post digging did not yield answers for........would any of the early Yawn Deere(pardon my language) models have the same gas tank as the original? or is the sediment bowl outlet too far inward? next...... looking at the rear of an original, what direction does the PTO turn,ccw or cw, and at what RPM? i think i stumbled upon a BOATLOAD(a closer inspection will be needed) of used PTO setups for my "O". last but not least, any leads to a download of the "creeper" manual for my "O". i'm sure that the wealth of knowledge and experience here will get all my ????? answered!
Joe
Original Cub Cadet/creeper/fluid filled ags/3 rib fronts(Third one I've owned)
Ih rear blade and rake
MF 10/3pt/all the toys(sorry but i like it)
MF 12 under construction(sorry but i like it)
IH 560 tractor
'47 Ford 8N Tractor
'85 Ford F 250 7.3 IH idi diesel
'99 Chetech Pug 4X4
Jari Monarch sickle mower
Old 11-18-2010, 09:46 AM
johncub7172's Avatar
Well, I dont know nothing about jd. It is best to repair/replace the Original gas tank....if thats what you are talking about. The other questions have been answerd many times. If I come across them, I'll let you know. A rear pto on a Original will turn counter-clock, if my memory serves me at all.
Old 11-18-2010, 12:07 PM
ljones's Avatar
ljones ljones is offline
I am pretty shure that the jd gas tank had the inlet to far in so it wont work
go here for info on how to remove rust in a tank
Click here
Here is the creeper install manual for your original
and Here is the parts list for the ud-6
Old 11-18-2010, 03:58 PM
Sminkey
Guest
Posts: n/a
Hey samspops!! ljones I don't think your links are working, at least for me they were a deadend. So I'm reposting links for UD-6 install manual and parts manual. Hope they work for ya!!
http://ccmanuals.info/pdf/Danco%20UD...%20Install.pdf
http://ccmanuals.info/pdf/Danco%20UD...rts%20List.pdf
Old 11-18-2010, 04:11 PM
ljones's Avatar
Thats wierd, thanks for reposting them.
Old 11-18-2010, 07:14 PM
Talking
Thanks ljones and sminkey. i knew that the very early JDs' used Kohlers, but my memory was slipping as to whether or not the spigot was set further in than the cubs. my tank is fine other than a very small weep in the factory seal. i'll take it off and sweat it when i do some painting this winter if we don't get thunder whumped with snow. by the way....THANKS kindly for the links to the manuals....it's been over 30 years since my last "O", and need a refresher on the lube service for the "creeper". when i get done messin' with it and get it all painted up, i'll definetly fire off some pictures! then i'm guessing i'll have to start looking for a 70 or a 100!!!!
IH 560 tractor
'47 Ford 8N Tractor
'99 Chetech Pug 4X4
Old 11-18-2010, 08:05 PM
Sminkey
Guest
Posts: n/a
Default No problem
For the last 2 days I've been trying to get my UD-6 off of my Original and still can't. I've just seperated the chassis from the rear end and still can't figure out how to get it off. Think I'm gonna pull the reduction housing off to see what's going on from the inside. I've pryed on it pretty good, but don't want to mess it up or bend anything. Will post pics later tonight of hopefully some progress. Yes, have a 71, but can't wait to get a 100
